Merc 98 Project
98iq
"Hi Everyone...
I am gettin
"Hi Everyone...
I am getting my motor ready for the winter and noticed that I have an oil leak. I checked to see if it was leaking from the drain/fill hole or the vent, but it is not. Seems to be leaking from behind the prop (seal i am guessing...?). I removed the prop, but have reached the "cover nut" and I am at a stand-still. I don't have the tool that is referenced in the Seloc manual.
Is this a tool that I should invest it or should I just make my own tool? If it is best to buy the proper tool i will, but I was thiking I could weld 4 nubs on the outside of a big socket and a handle to do the job...
Any advice from someone who has delt with this would be great!! :)
Thanks in advance!
Mike"
"piece of pipe, cut it out or
"piece of pipe, cut it out or weld lugs on the end"
"Mike, are you sure it's g
"Mike, are you sure it's gear oil and not simply burnt/unburnt oil coming down the exhaust?"
"Hi Guys,
Thanks for the re
"Hi Guys,
Thanks for the replies.
Graham, it smells like gear oil and when I drained the oil in the bottom end, it was milky. So, I am guessing I have a leak somewhere. I cannot see how to pull the lower unit off the rest as it looks like it is cast out of one piece. My grandfather painted the motor a few years back and may have covered any seam, but I just don't know.
My thoughts are that there is a seal around the prop shaft that is at fault? Does this sound familiar to anyone?
Thanks again,
Mike"
A nut at the front and a nut a
A nut at the front and a nut at the water intake screen and the works seperates.Pressure test to look for leaks BEFORE and AFTER your work!!
