cactusblues
"I've got a '78 Merc 1
"I've got a '78 Merc 110 (9.8hp) with carb problems. This was my father's engine and he was a Merc dealer/mechanic. I have the shop guide for this engine. He had the engine set up to run well at 3000' elevation. I am now trying to use it at 8000' in Arizona's White Mountains. It would not develop full power with the .045 jet he had installed. I looked up in the manual that at 7000+, this engine should have the .035 jet installed. I have had this done, but now the engine will not run at rpms above a fast idle without acting starved for fuel, run for a moment then start to die unless you switch on the choke. Still no full power rpm. I have tried adjusting the mixture screw, but not much success. I also could not find the .045 jet recommended anywhere in this manual, so wonder what might have been behind my father's decision to install that jet for 3000' usage. Any ideas?"
