Merc 96 200HP EFI Wonbt speed up
tob_mech
"Motor idles good pick up RPM&
"Motor idles good pick up RPM's out of gear
When trying to take off boat will not get on top.
Had mechanic check stator, power packs, timming,
low and high speed module and commpression.
Not sure what the problem could be appreciate any
help!!!!"
"I had identical symptoms on a
"I had identical symptoms on a 1998 Mariner 150 EFI. My problem ended up being the ECU. Be sure you check everything else because the ECU is expensive!! I took the injectors out and had them cleaned. I used a temporary external tank to insure I had good fuel and no hose problems. ECU was hard for me to diagnose 'cuz there was always fire at all 6 plugs, timing advanced, injectors fired (I even wired in a light and watched it stay lit longer at higher RPMs).
Be sure to check the head temperature sensor. RPMs will be limited if it sends signal to ECU that engine is hot.
Good luck."
