Merc 9.8 lower Question
rustymich
Took the lower off to reseal have the top end done took the prop off and the screw in ring how do I pull the seal around the prop shaft do you need a puller to remove it thanks...
CAREFULLY push it out the back with a long, slim punch. I grind the end ot the punch with a notch that clears the bearing while pushing on the seal.
Jeff
Pulled it today and resealed also adjust the shims now it does go in reverse and locks in I new something was wrong there..
