"recently bought a boat in Mai
"recently bought a boat in Maine that the gentlemen used on Sebago lake for a number of years. The engine looks great and has less than 500 hrs. As far as winterizing the engine, since it has only been used in fresh water, he disconnected all hoses and plugs, let the water flow out, then used an air hose to get the remaining water out. He's used this method for years with no problem. Now that i have this boat and it's going to be used primarily in salt water, should i run anti-freeze through the system anyway to coat the inside to prepare the engine for salt water use? or dont bother?. Another issue, pencil zincs. Should i put them in the manifolds for salt water or can i disregard?. i'm thinking of running the engine, then winterizing it properly to avoid any long term headaches, any suggestion? Thanks, Matt"
