Merc 6hp 2 stroke year
cowboy
About time i foumd a good site
About time i foumd a good site.
Can any one help me with the year model of my merc 6hp 2 stroke serial no 09784231.
One more question? were it says pull to prime the sticker is missing all i can make out is an arrow? which direction should i turn it and does it matter?
Have tried it in all postions and does make a diffrence but were should it be?.
Thanks heaps. Cowboy.
"09784231 does not compute. 0G
"09784231 does not compute. 0G maybe? The knob turns right (cw) to raise the idle speed. If it does not work, than see if the link rod is upsidedown. The L bend in the rod points up towards the flywheel. Where it connects to the spark arm. "
"Thanks the serial label reads
"Thanks the serial label reads.
09784231
MARINE POWER EUROPE,INC
DIVISON OF BRUNSWICK CORPORATION
B4800 VERVIERS
MADE IN BELGIUM.
Thanks again for letting me know about that prime knob."
"thanks Graham, and thank you
"thanks Graham, and thank you Bandit you were right that connetor rod was upside down CHEERS to you both.
One more question about the fuel mixture screw is their a set rough guide how many turns out from fulley closed it should be?. or would i be better just to adjust it while going at full speed in the water.
it seems to rev all right but you can notice a diffrence in speed while moving on water. replaced filter, fuel, 2 stroke oil added fuel doctor which made it better cleaned carby. goes well but think it needs the mixture screw tweked a bit what do you think? every thing i do makes it better but just not 100% kind regards and thanks again. Mark."
The fuel screw is only set at
The fuel screw is only set at idle. Open it up just enough that it will idle properly. ~1/1/4 turns.
Than gun the throttle and see if it bogs down or stalls out when you cut it. If so than move it 1/4 turn richer until that goes away. And that is it.
"thanks again bandit your wort
"thanks again bandit your worth more money (ha ha ha) last time i went out got 22 snapper all over a foot so the motor not going 100% did't really bother me. but next time its going 100% imagine what s#*t i can get up to. thanks again mate happy BCFD. (Boating, Camping, fishing, Drinking) got to love it. Mark (Cowboy)"
