Merc 650 Reverse Gear Won't Engage
I replaced gear parts, seals, and re-assembled. I did get forward, neutral, and reverse to engage initially. But after a short run, the reverse gear won't engage. Should I remove a shim? Even if I rotate the drive shaft manually, it won't engage reverse.
