Merc 650 3 cyl problem
instigatr
"hello guys.
been reading thi
"hello guys.
been reading this forum for a few days regarding my old mercury outboard motors. the question i have is in identifying my most recent one. it is a merc 650 3 cyl 2 stroke. that is the easy part. now for the serial number. it is 7003413. i have triple checked it to make sure i am reading it right and it is correct. for what i see, that number is to early for this engine and/or it is not a US engine. can someone help me, i need to rebuild the carb.'s and such before i try starting it.
thanks for your help.
Aaron"
"also, as i have no history at
"also, as i have no history at all on this motor (got it for $40) what kind of maintenance should i do? i have little knowledge about boat motors in general, but have very extensive automotive knowledge.
thanks
aaron"
The 650 triple came out in 72
The 650 triple came out in 72 and became a 70HP in 77 i think------Now for many MERCURY fans it is not high on the hit parade.The lower unit is somewhat small for the job.Before you spend a lot of time and money check it out---compression test and spark check-----Pull the bypass covers and inspect pistons and rings. Install a new impeller if you think the motor " is a good one " and a keeper.
"Aaron, I would only add to th
"Aaron, I would only add to the above that first, your assumption is correct, that is a Canadian serial number. The Canadian records are horrible but does look to fall into the 72 or 73 model year."
