"Hi all,
Like to say, i hav
"Hi all,
Like to say, i have gone through a lot of these threads, and your advice has been very usefull thus far.
I am new to the whole scene, and i need some advice on my unit. I know its a 1971 650 from its serial number. I bought the boat with the motor complete from my Brother, almost a year ago. Since that time, it has not run for a full 6 months, when i briefly started it up, to see if it still runs, and not since then.
Now i tried working it this weekend again, to get it running for good now, and get it certified. However i am having difficulties starting the unit now.
Firstly, the choke on the motor (manual and electronic) is not working.
Secondly, i cannot disengage the gearbox from forward, to Neutral nor Reverse.
I think also the carbs are dirty from the old fuel in the tank.
My question is this. How difficult is it to remove the lower unit, to get to the shifting mechanism? http://www.marineengine.com/discus/messages/12479/334438.png"" alt="""">
I found this image in another thread. Does the main shaft, the shifter shaft and the water pipe all come out without a problem? Is their anything special i should take note of when removing the unit?
Second question. Will the motor struggle to start when the gearbox is engaged? I had it running shortly, but it dies after a short while, then i struggle to get it to start again. Could this be becuase of the lack of a choke, or posibly a dirty carb?
Also, does anyone maybe have the part names of the parts numbered in the picture above?
Alot of questions i know, but i hope someone may be able to help me.
Thank you in advance."
Like to say, i hav
"Hi all,
