1A602189
SN 1A435211
Replaced cap, rotor, plugs midway through last season and we ran well.
This season it ran fine for the first ride after lunch about 15 minutes. Next trip out it would start missing at cruising RPM starting at about 2000 to 3200. Above 3200 it seem to smooth out although it would occasionally backfire at WOT.
Put it away, couple days later went out and it would not start. Engine cranked, seemed to occasionally fire but then not start.
Left it again for a couple days went out and it started right out. Got in and drove it and it would not miss after about 15 minutes.
Couple days later started it up went out and after a few minutes with the engine up the temperature it started missing in mid range again progressively getting worse. This time it would not even smooth out if you put the throttle down. Eventually it was running rough below 2000 and eventually quit on the water and would not start again.
Next morning went out and it started but driving in a bit it would consistently miss when throttling up.
Hold the rotor everything looks clean no signs of arcing.
Pulled the fuel filter dump bowl and let it settle and see no trace of water. Fuel filter is a little discoloured black but not bad.
Removed the aluminum hose barb coming from the tank and the check valve was perfectly clean. My boat mechanic advised me to knock the check valve out of that fitting For better fuel flow so I did that.
Disconnected the barrel connecter on top of the engine hit it with a little WD-40 to make sure there is no moisture issues.
None of that worked still doing the same thing.
Wondering if it could be coil or ignition module?
Any other thoughts?
SN 1A435211
Any other thoughts?
