"Finally got the tub in the wa
"Finally got the tub in the water after a lot of work on it.
Rebuilt engine
rebuilt Carb
New Fuel pump with filter
New water/ fuel separator filter and carb filter
Timing set a 8 degrees BTDC
Points at 22 thou
After a half hour in the lake, new plugs showed dusty brown burn pattern, with No.1 showing a tad rich.
At idle pulling off spark plug leads show noticable miss on each cylinder.
Idles at @700 seems to shift into forward and reverse fine.
17 Pitch prop according to the stamp
Electric choke is working fine.
Can't supply a RPM number as I have a tach on order.
On an 18 Ft. Deep V hull with two adults 20 gallons of gas and two 7 year old kids.
This thing is so sluggish it wouldn't pull the skin off a rice pudding on the hole shot. Takes around 15-20 seconds to get up to plane speed.
Any suggestions welcome.
(yes the trailer was left on shore and not attached to the boat
TIA
Bert"
Rebuilt engine
rebuilt Carb
Points at 22 thou
TIA
Bert"
