"hi all,
i have a merc 350
"hi all,
i have a merc 350 (260), an 898 outdrive, 2 bbl rochester carb. i just rebuilt the carb w/ a mercruiser rebuild kit. i have several questions.
below the accelerator pump there is a steel ball (looks like a bb). my old one was corroded in place. it was so bad i had to use a pick and dig out the junk/rust/debris just to get the ball out. i have gotten the hole this ball sits in as clean as possible, and from what i can tell it doesn't go anywhere. that doesn't make sense since there was a check ball in it. should i take the carb back apart now that i've picked that ball and crud out and re-soak it? all the passages came out nice and clean after soaking and blowing out w/ comp. air, except for this one. i guess because it was so caked up the soak must not have penetrated it. the rebuild kit said there is a retainer on some models. but the ball it said is standard (didn't specify ball to only some models). i didn't see a retainer in mine, unless it was disintigrated. so, is it possible that it's a blind hole (dead ending) or does it have to go somewhere? should i re-soak to open passage? can ball be placed down in hole with no retainer?
i appreciate the time you all take to read and answer our posts."
i have a merc 350
"hi all,
