MrHProblems
This is going to be a relatively long one I believe.
Information:
1996 Bayliner Capri w/ 3.0LX Merc.
I stored the boat for the winter and came back this season to take it out on the lake and BAM, crank no start.
I narrowed it down to no spark, replaced the distributor, rotor, cap, etc(made sure to set the timing, it’s 8° before)
replaced the ignition coil,
bypassed the kill switch temporarily,
unplugged the shift disrupter( connected the 2 wires on the harness to each other),
Check continuity of all the plug wires,
Made my own EST-Coil wire harness because the factory one appeared to be bad,
New spark plugs,
Tach is unplugged from behind the gauge cluster,
All fuses are good.
I also tested to see if I’d get spark directly from the coil, no spark. I have 12 volts entering the coil via the purple wire that is in the same connector as the grey wire, I also have 12 volts leaving the coil through the harness to the distributor, as well as through the plug wires going from the coil to the distributor. Everything also appears to be grounded properly to my knowledge.
At this point I have no clue what else it could be.
Information:
New spark plugs,
All fuses are good.
