Bayliner93
Hey guys. I have a 93 Bayliner that I've owned for about 3 years. It has a 3.0 L Mercruiser Alpha 1 sterndrive. I had it mothballed for about 2 years. Stupid for me I didn't drain the gas or use stablizer. I tried starting it about a month ago. I finally got it running, but only in "throttle only mode". I had to throttle up half way and reav up to about 5k. It'll run for awhile there, but I didn't won't to run it too long at that high RPM. I then changed the oil with new filter, flushed out the old gas, changed the plugs, and added Sea Foam to the new gas. I tried starting it again, same results. It will not start in neutral. I then took the carb off cleaned it, including the inline filter, as best as possible with carb cleaner and blew it out real good. I didn't open up the bowl or mess with the jets. That gets into uncharted territory for me. So I re-installed it. I set the idle and fuel mixture to the correct specs, as well as the choke (it has electric).
I tried starting, got the same results again. The vacuum hose appears to be draining fuel out of the carb, after running for 5 mins or so. I'm not sure if thats normal. I'm wondering if maybe the floats are stuck and causing flooding. The only other thing I didn't check is the fuel filter on the fuel pump, mainly because removal access is a pain. I'm thinking now I probably should attempt it, as well as the bowl, floats, and jets.
Other then that I don't know what else to do.
Any advice will be much appreciated.
Thanks,
Jim
Thanks,
Jim
