riverbarron
I picked up a 98 searay 175 fixer-upper with a 1985 3.0 inline 4 merc. On the merc carb air breather the timing spec is 1 degree btdc and the firing order is 1-4-3-2. On the merc valve cover the firing order is 1-3-4-2. What's up. Also, when i ck / set the timing at 1 btdc it only goes to 8 btdc at 2000-3000 rpm. The engine also has poor throttle response. I rebuilt the carb, flushed the fuel tank, chg oil/filter. I used the thunderbolt electronic ignition from the 98 engine. HELP !!!!!!!!! ADDED INFO
