"ok, i know there are tons of
"ok, i know there are tons of threads with wiring diagram links, but none seem to exactly fit my application. mine is an old 79' 898 outdrive. merc. 260 with elect. choke, 2bbl rochester carb. i already hooked up the orange wire to the oil pressure sender. i'm pretty sure the green wire goes to the temp. sender. my choke wire is identified. (i can't remember what color it was, but it ain't my problem.) the ones i'm not sure of are as follows:
2 brown wires that go to the same crimp connector from harness
2 light beige wires that go to the same crimp connector from harness.
1 purple wire.
1 black wire.
-these all must deal with the coil and dist. and i'm pretty sure the black is equppment ground."
1 purple wire.
1 black wire.
