MERC 25EFI SHIFTER ENGAGMENT
B
bradley_s
Guest
"I HAVE 2008 25 EFI , AND WHIL
"I HAVE 2008 25 EFI , AND WHILE CHANGING OIL I NOTICED THE PROP IS NOT ENGAGED WHILE IN GEAR? FORWARD OR REVERSE. IT SEAMS TO WORK FINE WHEN RUNNING. IS THIS NORMAL, OR A SHIFTER PROBLEM?
IT IS WROUGHT IDLE AT 900, BUT SOUNDS GREAT AT 1100 OR MORE. IS THIS NORMAL?
THANKS YOU"
"Hi there!
Welcome to the f
"Hi there!
Welcome to the forum! Ye Olde Sea Dawgs here will help tirelessly!
If it runs fine, don't worry.
On the rough idle, could be stale fuel in the system? Are you using correct octane?
With such a new motor, I'd consult the dealer you purchased from to be 100% certain.
Regards from a cold and wintery Johannesburg in South Africa!
Benjamin."
"With the motor in FWD the pro
"With the motor in FWD the prop should move clockwise with a slight clicking noise, but should stop dead if you try counter-clockwise - the opposite should be true when shifted into reverse.
That would be normal..."
