arkansashunter
Hello,
First off thank you for reading this thread. the forum has already helped so much.
My motor has no fire getting to the coils
It is a manual start 1992
Ran test on the stator and trigger and the results are as follows (im not sure if i had all the settings just right on my meter, electric guy i am not, so its safe to assume the decimal points could be off... The numbers seem to line up with my book tho... )
Stator
Black white to ground 142
Black yellow to ground 3.17
Black yellow to black white 3.05
Trigger
Brown yellow to brown .80 (20k setting on meter)
Would this mean that it has to be the switch box, assuming the kill switches are good (i disconnected the kill plug from the switch box and pulled the cord and it still had no spark at either plug)
If the switchbox is bad and i replace it will it be compatible with putting electric start on the motor? I do not have the recharging stator (the red one).
I do have a junk 99 that all the electronics work on tho and was going to rob the electric start components of it to convert mine.
Thank you
Stator
Trigger
Thank you
