"I have a Mercury 25HP 1997 S
"I have a Mercury 25HP 1997 Serial No. 0G444580 on a 4m forward control alum runabout.
Out using the boat on the broadwater yesterday, suddenly I lost power and the engine revved out. Managed to limp home with engine just above idle, but every time I opened throttled it was as if the prop was cavitating.
Have inspected the lowerend and the prop looks undamaged, but the fin on the trim anode beneath the cavitation plate has broken off. The prop shaft spins freely in neutral, turns the drive shaft one way and rotates and clicks in the other direction in forward gear and turns the drive shaft in both directions in reverse. ( I think the ratchetting in one direction in forward gear is normal as Graham Lamb mentions it in one of his posts)
Is the loss of the trim anode fin enough to cause such gross loss of drive power? The fin snapped off about 1/4" from its base. I removed the trim anode and smoothed out the rough edge with a grinder and put it back on the lower unit and tested the boat on the water. But still the same with the engine revving out under power.
I am concerned that it is just not cavitation from loss of the anode fin, but could there be something amiss with the gear train in the lower unit, as if there is a slipping clutch.
Not sure where to go fom here, prop looks OK and drive train seems intact, could there be something else wrong?"
