Recently bought this second hand motor, (S/N 0D918709) and starts up fine. Cooling discharge rate seems to be extremely low at only a steady drip drip rate increases slightly with motor speed but never achieves a steady stream. Replaced water pump impeller and ensured the clear discharge line coming from the engine block is unblocked. Is there anything else I should be checking before digging deeper into the power head and lower unit's water tube?
Also, the manual I have indicates that there is a seal and spring assembly supporting the water pump impeller. I did not see either of these when replacing the impeller. Any suggestions appreciated. Thanks.
