"Hi all, new to this forum wit
"Hi all, new to this forum with a couple questions. I have a 1980 90hp 6 cylinder Merc, I have been told that the only differece between this and the 115hp powerhead is the carbs. Can someone verify this? Also,this engine seems hard to start when cold... compression tests good, spark on all 6 plugs is good. Any ideas? One more thing...it tends to grind when put in reverse. Could this just be a shifter cable out of adjustment or is there something these gearcases are noted for? Thanks for any help you can give.
Chris"
Chris"
