Brian Darley
I have a 96 Rinker Jetboat with a Mercury 120XR, I just finished replacing the Stator and Trigger and flywheel due to the magnets coming off on previous owner. I have the boat running pretty good, but also just noticed that the Tach is not wokring. I pulled the dash apart to get to the gauge to verify the connections and to check for voltage and such. I can go across the ground to IGN and I see my voltage, I can go from ground to Send and I can see voltage and it increases as I run the throttle up, but the tach doesn't read.
When the ign is off the tach goes up to about 1000 but when I turn the key to on it drops to 0 and only wobbles as I start the engine, but thats it. I stopped by my local trade shop to pick up a used one for testing and it does the same thing, so I am assuming my gauges are good.
Any thoughts and can I bypass the voltage regulator to get the tach working, or is it best to replace it?? Boat runs good for sitting for over 3 years, just have to finish adjusting the carbs mixture and a slight leak in my fuel system.
