smokinjoesid
I bought the only kit available for my model outboard. everything seems to fit except the impeller will not go over the shaft right at the spot where the impeller fits at the pump. The shaft seems to get a bit thicker there at the pump housing area. The impeller will not even go on without the retainer pin, it won't go down. I've tried cleaning the shaft good, even lubing the impeller a bit (I know I shouldn't but I wanted to see if it would go on). Even tapping with a hammer - another thing I should not do - won't get it over the slightly thicker area. Is the shaft supposed to get thicker at that point or has something happened to the shaft? I have to believe I have the wrong impeller since it came with the kit and everything else looks exactly right. I can't compare the impeller to the old one as it required cutting off the shaft, it was 'seized' on.
Any help would be greatly appreciated.
