mariner_115
"Hi all,
Right i have a 4 c
"Hi all,
Right i have a 4 cyl 115 (4Carb) Mercury that i overhaulled, The engine is good but i dont know what is happening to my Carbs. Okay the first time i started the new engine i had to use the normal outboard oil from our garage (mobil) and i mixed a little more oil than normal for the first run. Im not using the oil injection on my engine, im premixing. (oil injection removed) So the engine ran about 2 min with that mixture then it started running very rough.. u can hear that it isnt running on all 4 cyls. To me it sounds like its running on 1 cyl the top 1. Spark is fine on all 4 cyls. So when i press my key in ignition to choke(when engine is running rough) then it comes alive for a few seconds. Witch means that its a petrol problem.
Then i took all the Carbs off and cleaned them, When i started it was Fine!! Runing like a brand new engine. But Since then i have done 40 hours with NO problems using the Quiksilwer Outboard oil. Last weekend i went to the river on a sunday so i had to use the normal outboard (The same Mobil) as my first start. So it died on the river with me. Now its sounds just like the first time running on 1 cyl.. So i have to take the Carbs off again to clean.. Why is this happening??
Its clogging my carbs..
Can there be a problem with the cheaper oil?
Thanks for taking the time to read about my problem!"
Right i have a 4 c
"Hi all,
