jbuchholtz1
I need some advice on a 1984 Mercruiser 470. I pulled this boat out of a barn. It hasn't ran since 2005. I was told the heat exchanger was cracked. It appeared there wasn't any antifreeze in it because I could not see any in the reservoir when I took off the cap. I pulled the riser off and found that the exhausted chamber on the stern side of the manifold was full of antifreeze and there is a crack between the front and rear exhaust chambers of the manifold. there was also antifreeze in # 4 cylinder. Compression is between 155-165 all cylinders. I did order a new exhaust manifold but am not convinced this is the problem. The research I have done so far indicates a cracked manifold but the only thing on either side of the crack seems to be exhaust chambers not water jackets. There isn't any water in the oil. I don't want to waste all this time fixing it if there could be more to it. The heat exchanger was replaced a few years back and still looks brand new. 100% checks out as being good no cracks. Any advice would help.
