JCosta
Hello,
Looking for some instruction and advice. I have a 1982 Carver with twin Crusader 220's. I'm having an issue with the port side engine. Port engine starts up and runs smooth at idle with no smoke but as soon as I throttle up the engine dies. I replaces all fuel lines and filters on both engines, canister and carb. After running both engines at idle I pulled the canister from the starboard engine and it was full of clean fuel, no sediment. I pulled the canister filter from the port engine and it was only half full but no sediment. I have two 92 gal tanks and get the same results when I run from either tank.
I'm wondering if I could have a problem with the port side mechanical fuel pump. Can it be rebuilt or does it have to be replaced. Has anyone done it?
Some history... I bought the boat in December (2014) and was told that both engines had been rebuilt by the previous owner and only had 230 hrs on the rebuilds as indicated by the hour meter. The starboard engine looks like it has a new fuel pump... newly painted but the port looks different... dirty for lack of a better word. One more bit of information... the boat has been on the hard for 2 years.
John
John
