ME-F40E EFI
1A40302ZB 40 EFI 4-STROKE (3 CYLINDER)
Serial Number 0P195345
Hi all,
Any help is appreciated
There is no error beep, only the long control beep when the key is turned.
The injectors (all 3) pulse gasoline (no spray, is this normal?)
The VST tank is clean.
The external tank is swapped out incl. The hoses and prime ball.
The fuses are replaced with new ones, just to be sure.
When it "starts" and stops running I need to open the throttle lever on the remote than crank it over a few times, close the throttle lever crank again and it runs again for a few sec. The longest run time I got wax 4a5 sec. First the motor idles up and then down, runs on idle and shutsdown.
Regards Paul
Hi all,
Regards Paul
