the casting as two copper pipe
the casting as two copper pipes connected into it with rubber seals should there be a hole connecting the through passage between the pipes and the thermostat ? If so what size should the hole be ? At the moment the casting as no hole but there is a lot of rust so any hole could be blocked. There is no bleed hole in the thermostat so when engine starts to pump raw water dose it go to deadend in block until thermostat opens?
