Why would my bail a matic not be working? Impeller is in great shape and the water tube into the top impeller housing is sealed, I actually sealed it with another type of water pump tube insert because I thought that was the problem. Can't figure it out. Motor impeller pumps fine. The top impeller housing where the screw is should be open to the impeller correct? Because you can see the impeller, I would imagine that is where the bail water comes out and joins the exaust. Any input on this would be much appreciated. Thanks, dillon
