I have a 70s model mercruiser 470 mc-1.
It will not shift into reverse with the upper cable attached.
But it will shift fine when I disconnect the upper cable and move the shift arm manually.
The boat did shift when I bought it. I replaced the bellows as well as the lower shift cable and now I'm having this issue.
I tried adjusting the lower cable to the 6in requirement in full forward but it doesn't shift into reverse with the upper cable attached.
Only when is disconnect the upper cable will it work.
What are the adjustments needed for the upper shift cable??
