Max rpm Evinrude 70 1991
ged
can any one tell me what max r
can any one tell me what max rpm is for this engine mine will only rev to 4000. also at what rpm should i set the ignition timing with the strobe. is it 19 degrees b.t.c. thanks Ged
"thanks JW how do you set the
"thanks JW how do you set the timing at tickover, if possible. any idea why this will only rev to 4000. Ged"
"tickover???
timing is set at
"tickover???
timing is set at WFO throttle,..or 5000,.
make sure your timer base,is advancing to the 'stop'...make sure carbs are open fully at wot...
do a full ck up on eng,to verify condition....comp-spark--fuel delivery.
ck anti syphon valve on tank if there.
chg fuel filters...
last but NOT least...prop condition and PITCH..u may just have too much prop."
is this a barge......or light
is this a barge......or light aluminum boat?..pontoon or runabout...bass rig or bay rig?
"its a 12 ft fourwinns freedom
"its a 12 ft fourwinns freedom 150 bowrider. it will only rev to 4000 with muffs on. new coils, plugs,cdi box head gasket, carbs spotless, comp 125 psi on all cyl,s,new filter. spark jumps 7/16 gap on cranking, reed valves look o.k.seems to be plenty of fuel."
Do not rev a motor while runni
Do not rev a motor while running in the driveway. I suggest you calibrate your tachometer.You should find a shop that has a MARINE DYNOMOMETER to check this engine out.Too much guessing has already been done.
