markvanness
I have a Pair of 1997 Cursader
I have a Pair of 1997 Cursader 454 XLI engines in my boat. 2 weeks ago the starboard engine cut out and I had no ignition or engine status lights. When You turn the key there was no power to the fuel pump..... A mechanic fixed the problem with a what he called relay inside the box next to the throttle body. He left me the bad part telling me I should probably replace the port engine relay..Sure enough the same thing happened to my port engine. I played with the relay and was able to get tempoary igintion so I know it's the same problem. I can't find the part number. The numbers listed on the relay are 5156 and above the relay diagram is another listed number 14089936. Can anyone tell me what this part is eactly and how to get it?
