Mariner year model
excalibor67
"I have a 30m mariner. The num
"I have a 30m mariner. The numbers are as follows
689 s
035300
i have read, and assume the S stands for short shaft. And the M stands for manual start(Rope).
Please tell me what year, is it a yamaha built?
Thanks for any info.."
"Hello Johnny,
"Hello Johnny,
yes, it is a Yamaha built 1989 model. It is a carbon copy of Yami's own model 30AM built between 79 and 85..."
"Thanx for a fast reply, One o
"Thanx for a fast reply, One other Ques. if i may.
what is the small fin/nipple in the pic below.Sacrificial anode or trim for pulling left or right? It looks as if the bolt in center can be loosened,and the plate turned..
sacrificial anode or sun-dial...lol
"Sometimes both. If it's m
"Sometimes both. If it's made of a less noble metal (zinc or magnesium etc) it will work as an anode.
And yes, it can be (set) to offset the torque created by the prop to help the boat track straight.
So on flat water, on a windlass day if you notice that your bow tends to veer say a little to the right, you can move that fin a little to the left to try and get her to track properly.
Sometimes there will be little tic marks or even numbers printed in the disk directly across from the fin and a corresponding marker on the bottom of the housing to allow you to "mark" the correct spot for proper placement after removal.
Mostly it's a trial and error kinda set-up. Obviously, the higher horsepower of the motor the more torque and hence, the greater need to fiddle to find the right spot."
"I just got the motor (at
"I just got the motor (at a deal i hope)lol.
gave a elect.trolling motor and 100 bucks.I kow several people that saw it run,but said it starved at WOT. The guy said he had been in the fuel pump,so i just ordered a new one.The motor looks as if it sat more than it ran..clean. Have not ran a compression check, but head looks great.No heat distorsion at all..Thanx again Graham, from what ive read, and your fast answers, your well versed on these motors.
head shot
"You got a good deal, I would
"You got a good deal, I would expect this model to sell for 750-1000 bucks in the used market.."
The engine I have has no seria
The engine I have has no serial number label on the mounting bracket.
The cover has Mariner graphics and 40HP sticker. The engine is stamped with 6E900 and has a small silver plate stamped with 080018 (serial no.?)
Can anyone tell me the model year from this?
Is there any way of confirming it is 40HP?
"Mike, the 6E9 part indicates
"Mike, the 6E9 part indicates that it's a Yamaha built Mariner.
The 6E9 if stamped on the engine would definately confirm it's a 40 horse.
But the 080018 is not part of the serial number.
There might be another tag somewhere on the engine with the 6E9-xxxxxx."
"Graham,
Thanks for this in
"Graham,
Thanks for this information, i've found 6e9 in a few places so far but no other serial number.
One or two parts have Yamaha symbols on them so your spot on there, thank you.
I've attached a couple of photos (one of the disc i thought was the serial number) any suggestions?
"If the decal containing the f
"If the decal containing the full serial model is gone, it becomes difficult to narrow down the exact year - often the best you can do is the model run.
There were 3 versions of the 40 Mariner that started 6E9. A twin carb model, a twin carb with auto-blend and a twin carb with (real) oil injection."
"Hi there I have been looking
"Hi there I have been looking to find my Mariner year...... no luck, PLEASE HELP... thx
the nubers I have are as follows
Mariner 20
653 S 11646
it also says made in Japan.
thank you"
Please help with the model/yea
Please help with the model/year of two Mariner outboard engines. 40hp. serial numbers 890-821358-01 and the other 890-821358-C1 (two stroke motors)
Thank u
gawie
South Africa.
"Thanks,i just spotted the ser
"Thanks,i just spotted the serial numbers of the two engines 09925106 and 09925112 40ELPT model 1996. Made in Belgium.
Gawie
South Africa"
