" Tony or Joe, I have a 45hp,
" Tony or Joe, I have a 45hp, 4 clyendar Mariner, I believe it is a 1987. I just got the motor and dont have a book for it yet. Here is the problem. I had a lower unit leak, I wanted to change out the impeller and re-do all the lower unit seaLs. The lower unit was pretty salted, I had to torch off the pro hub and cut off the prop, then I had to chip out the threaded nut inside the lower unit to get to the bearing carrier. With allot of heat I did get the bearing carrier out. Now the problem, I am sure I did get all the lower unit nuts out and with allot of heat I could get the lower unit to "seperate". I appears it is all loose and I got it to seperate but only a half inch or so and thats it! I seems loose arround the lower unit bolts but it is definately hung on something. My fear is it is stuck on the drive shaft where it splines into the crank (ouch).
My question is, is there something I missed taking off, perhaps something in the shift linkage or does it just spline up like most mercs? Perhaps something in the anti reverse linkage? Perhaps a pin or bolt I missed? Now if it is stuck on the drive shaft/crank connection can I take off the pinion gear nut and pull the drive shaft through the water pump housing and out of the foot? How about undoing the power head bolts and trying to pull the power head instead. I am considering putting it on the cherry picker, chaining the lower unit to the bottom and the power head to the top and see if a little hydrolics can seperate these two peices. Is there anyway to apply heat to the problem area? As always any assistance you guys can offer is greatly appreciated!
Thanks "
Thanks "
