francois_jacobs
"Hollo to all<[img]"http://www
"Hollo to all
The standard timing for my mariner bigfoot 60hp is idle timing 2 degrees/6 degrees ATDC WOT timing 22 degrees BTDC idle mixture screw turns out 1-1/4 to 1-3/4. Is this settings for sea level
My elevation is +/- 4500ft to 5200ft(1400m to 1600m +/-) above sea level
What must the main jet size be in the WME 33 carburators and the timing for idle and WOT at this elevation? The carburators has got .060 jets in. The timing is set at 0 degrees on idling and 22 degrees BTDC at WOT. The motors doesn't have enough power. I've done a compression test on the 2 mariner Bigfoot 60hp engines thats on the boat. All 3 cylinders on the motors gives me a reading of 100psi or 7kpa. The compression is not the problem. Can you please help me resolve this problem?"
"Hollo to all
