Mariner 75HP 3Cyl wonbt start
jkon
"Can anyone give me a list of
"Can anyone give me a list of items to check please; I was out on the boat for a good three hours, towed it back home, put the mufflers on to clean out and the engine wouldn't start, it turns over with ease, the safety switch is ok (I tested it) new plugs put in (because I had them as spares), havent tested the spark yet, there seems to be a definite smell of petrol after I have tried to start it when turning it over a good few times; all help will be welcome, cheers...by the way...great site, just found it."
"Test the spark first. If ok,
"Test the spark first. If ok, remove the spark plugs and let the cylinders dry out - it may have flooded.
It is quite common that a motor will run fine and upon throttling down a clog stops the float from closing properly and the engine floods out."
"Hi Graham, thanks for the adv
"Hi Graham, thanks for the advice, I'll check it out the moment the rain stops battering down here :) . Is there an easy way to check the float and how would you test the spark on your own without someone at the helm turning her over.
cheers"
"You have to pull the carb&#40
"You have to pull the carb(s), disassemble, clean, and possibly add a kit.
I check for spark with a timing light - got "bit" once too often using other methods..."
