Hello,
I have a 1997 Mariner 75 2 Stroke which runs great at anything over 2000 rpm, but when at low speed has started randomly cutting out. A quick squeeze on the primer bulb shows that the fuel line is empty and when primed again will start fine again.
There seems to be no pattern to when this happens, it might happen within a few minutes and then quickly again from then on, or it might not happen at all.
My guess was there was a fuel leak in the line pre pump, I have tried with a short new hose and the same problem (though I have not ruled out the fuel connector on the engine)
The engine runs fine usual speeds, but there is a speed limit for a while coming out of the mariner and it is not good news there
Does a fuel line air leak sound liked, or something more engine side?
