Mariner 60 elpto 2001
"Motor in normal running posit
"Motor in normal running position.Remove lower plug, then the vent plug at the top of the lower unit.Refill using a pump/ or similar device. You fill oil using the drain hole and pump oil in till it comes out the top. Install the plug at the top, remove tube / pump or similar device from the drain plug and install drain plug.THERE IS NO OTHER WAY TO DO THIS."
