"when boat is not used for thr
"when boat is not used for three weeks the battery goes dead. if you take the cables off the battery to the engine sparks fly. after playing with the wireing in the engine, if you dissconect the big red wire to the voltage regulator sparks no longer fly. what would be causing the voltage draw to the voltage regulator when the engine isn't runing? i already replaced the regulator with no luck. thanks"
