I have a mariner 40hp 2stroke 3 cylinder year 2004-2006, it worked fine for about half a km then it started slowing down till max revs reached 3k. When revving the engine using the idler it is reaching full revs
When boat is on trailer it revved 6k geared.
- I have checked the fuel filter inside the fuel tank
- checked pipe from tank to outboard
- dismantled fuel pump and cleaned everything with brake cleaner nothing seemed torn and needed replacement (although I am not that technical)
- carbs were clean ( I didn't remove the jets just inserted a wire inside all holes I could find + sprayed compressed air inside)
- fuel filter seems fine
- removing the plugs one by one caused the outboard to work not correctly so spark plugs should be ok.
- I have also changed a pipe from carb1 to carb2 to transparent to check if there is air but there isn't
Any other on the check list before I get the boat inside the water again
https://youtu.be/dIkC1P_j0f8
https://youtu.be/9VSWjxaw9Ls
