Gene Kimberly Esper
Hi guys,
I took my carburetors off and under the main plate on top of the carburetors, there are a couple rubber gaskets and a very thin metal plate that goes under the gasket in the carburetors. The rubber gaskets look like they are cracking, so I would like to replace them. However, the very thin metal plate that goes below one of the gaskets has 2 little divots (they look like they are manufactured that way). So my main question is, does it matter how the divots are positioned? The Mariner manual I have does not mention their orientation in the carburetor, but I don't want to put it in wrong, if there is a wrong way. Does anyone know? Reference#26 on the following diagram: http://www.marineengine.com/parts/m...carb/6e9400231-thru-6e9423162---el/carburetor shows the part, but there is no reference to the divots in the illustrations. The motor has 2 carbs, and each plate in each carb has the same two divots. It also looks like each plate is slightly bent or curved (again, both look manufactured in this way). Any help would be great. Thank you! God loves you-Gene 1987 MARINER SANSHIN 40 ELPTO Model Number 7040737
