I have a 40 hp magnum OC188149 with slight carb problem. I noticed that a small leak was coming from the fuel bowl. I took out the rubber gasket and found no tears or any bad spots on it so I flip it over and reinstalled it leak stopped. A small brass piece kinda fell out and not exactly sure how or where it goes. its called a fuel bowl baffle.Is it even really needed? but I'm not too sure if I put it back right. Because now I have a more significant leak when pumping up the blub.. fuel shoots out of the bowl vent. but not always a different times the blub firmed up nice and the motor fired right up. Am I in need of a carb. rebuild? another question...the wma-1b is stamped on the carb. are parts interchangable between other WMA- carbs?
Thaks Klag
Thaks Klag
