Mariner 30hp
Mattyboom
Picking up a mariner 30, needs some work so in just trying to identify it, any help greatly appreciated.
setuo with at tiller and electric start..
serial# 0G0853753
lookwd at the parts break down and from what I can tell I can pickup a carb from a 40 and reeds... My only question is do the reeds have a different cage?
Oil mixture?
Prop? (Going on a rib350)
what kind of rpm is cruse and what should I see at wot?
Serial# 0G0853753
Your serial number has one to many numbers in it which makes giving you accurate info a bit difficult due to being unsure of the position of where the extra number rests. If I remove the 5 between the 7 and 3, (0G085373) the serial number shows a 1994 MERCURY 30 MLRC/ALT. http://www.marineengine.com/parts/mercury_marine_parts/sn/0G085373
All that mentioned, It's probably a 1994 but you may want to recheck the number when you can. http://www.autorepairmanuals.biz/page/608045
This is what I found on the motor "0g085753" the extra number snuck in there, I'm sorry!
M
