Mariner 30 - Help identifying
98ron
Hi, I have just inherited a Mariner 30 and am trying to find the EXACT model/make/serial number etc for ordering parts.
It is a 2-stroke 2cyl electric start.
The badge says "Mariner 306...." followed by more numbers but the badge is damaged
Underneath, there are three boxes as follows:
Box 1 - Looks like 689
Box 2 - Illegible
Box 3 - 552048
"Made in Japan, Pays D'Origine Japon"
On part of the engine (looks like a plug in the casting of the block) is stamped: 552048
On the head (next to one of the spark plugs is embossed: T.3 68901
_______________________________________________________________________________
When I search here http://www.marineengine.com/parts/mariner-outboard/ , for "552048" or "689-552048" "689-01-552048" or any combination, I get no results.
I am taking a guess at this:
http://www.marineengine.com/parts/m.../30-2-cyl2strokeinternational/0n055505-up-bel
but i do not want to guess and any help to confirm would be much appreciated and an explanation of how you arrive at any conclusion.
I am starting this out in Corfu next month and need to take parts out with me as they are a headache to obtain in Greece.
Thanks.
IMG_4501.JPGIMG_3674 (480x640) (375x500) (300x400).jpgIMG_3675 (300x400).jpgIMG_4500 (300x400).jpgCapture.JPG
You have a 1992 model - last year of production.
It was built by Yamaha with 100% Yamaha parts and branded as a Mariner which was sold by Mercury.
The 689 part of the serial is the Yamaha designation. It means that your motor is "mechanically" a 1979-1985 Yamaha model 30AE. These were not a "sub-standard" model but they were NOT leading edge when they were sold. Merc contracted Yami to build these so they would have a budget option compared to a "brand new Merc". So basically you were getting a 1979 Yami, brand new in 92 for hundreds less than a 1992 30 horse Merc.
The part you can't read should read "EL" for Electric Start (from factory) Long Shaft (so meant for a 20" transom).
The 552048 part is the "actual serial" which indicates the 1992 production.
On Merc parts lists your model would be listed as a Model 30A.
Here's the link to this sites parts availability for your model - http://www.marineengine.com/parts/mariner-outboard-parts/30a/689550101-and-up-el
Thanks Graham. This is extremely helpful. Thanks for taking the time to reply.
As I undertake this project I will try to make my own useful contributions on this engine from my experiences.
So to clarify I have now had somebody in Greece check the engine and the following number is visible..
Mariner 30
30ELO = 30HP Electric (Ignition) Oil injected
689 (Yamaha) L (Long shaft) 552048 (unique serial number)
I am told by Bill Higham in Manchester (UK) that this is quite an unusual engine, however we have confirmed that the correct parts are here:
The only confusion is why 'Auto Blend' appears on this page, because this engine is oil injection.
If you are in the UK I can recommend Bill Higham marine if you need advice, parts and/or repairs.
Cheers.
http://billhigham.co.uk/
If someone could help it would be greatly appreciated I also have a 30AE with the badge that reads 689-S-101350 and have no luck in finding any parts or any information on the motor
Similar to a Yamaha USA 30ESN/ELN. Check out the Yamaha parts catalogs for either model, available from a number of US dealers.
Hi all,
I am trying to find better information on an engine I have been given and you all seem pretty on to it! I am not sure if that last bit is a 7 or Z but i cannot find anything about it online. It seems to say Mariner 30AM 689 302427. Here are some images:
It is a 3 I found out. 689-L-302423. I finally found an owners manual.
"This motor was built by Yamaha for Mercury and is mechanically identical to a 1979-1985 Yamaha model 30AE"
So parts for that engine will work for this engine? Would this still be circa 1983?
Thanks for your reply boscoe.
