Hi - first post & looking for a bit of advice..
Motor is a '89 Mariner with a WBC carb. Runs great until WOT, where the power definitely drops off without any noticeable detonation. I've always assumed it's lean condition. Pumping the carb primer at WOT makes no difference.
Once the motor has been run hard for 30 mins it can then be opened up wide without any bogging.
I have factory manual, link and synch done to the letter, new fuel, new plug,cleaned filter / separator.
I've replaced the diaphragm in the fuel pump, replaced a perfectly clean highspeed jet and replaced the mixing chamber gasket as the manual suggested with no change.
I'm starting to think about the coils or magneto. A buddy suggested I consider the crank seals, but tearing apart the power head would be last resort.
I’d appreciate any comments / suggestions
Shaun
Shaun
