Mariner 25 over reving
N
Nick Andraka
Guest
" My Mariner 25 runs fine unti
" My Mariner 25 runs fine until I get to full throttle, then is revs up like it is out of gear, if I pull the throttle back, it "re engages"
and runns fine till I try to put it up into full throttle. This was with 4 in the boat.
When I tried to wind it out with just Me in the boat, it would not do it.
There is no grinding or other "gear noises"
It is like something is slipping under a heavy load. It just started to do this, it was running fine for years.
vintage mid 80's Mariner 25
any idea's ??
many thanks,
nick "
It might be possible that you
It might be possible that you have 'spun' the hub in your prop? Or the prop might be the wrong pitch/size for the application and you are cavitating...?
" I have not changed anything
" I have not changed anything (prop, pitch)
It just started doing this last time out.
It does not come on gradual, just gets to a certian point and boom, the moter revs up and the boat looses foward thrust.
Is there a "satey" clutch in these engines ??
Thanks,
Nick "
NICK THERE IS NO SLIP CLUTCH
NICK THERE IS NO SLIP CLUTCH IN YOUR MOTOR CHECK ON YOUR WEIGHT DISTRIBUTION WHEN YOU AND YOUR PALS ARE OUT
" I had the same problem with
" I had the same problem with my mariner 20 (except it lost thrust with 1 person as well). the prop looked fine but when I took it to the prop dealer, the said it was twisted. a new prop solved the problem. must have hit some floating wood or something without noticing. "
" NEED HELP ON 30H.P.MARINER.I
" NEED HELP ON 30H.P.MARINER.IT RUNS GREAT AT IDLE ,BUT WHEN THROTTLED ITS DEAD . "
