The tiller throttle on my 25hp mariner (SN: 695 S 016466)is stripped where the shaft enters the plastic cam holding the ends of the throttle cable (shown below. After searching the forums, I found a replacement shaft with the plastic part attached, but I'm not sure how to get the cables off of the old one. The look like the lead end will push out the top or bottom once the cable is perpendicular but there's not enough play to get them to that position.
Do I need to undo the cables from the throttle body end (losing all those adjustments), to be able to swap this part out. Just looking for confirmation before I start undoing things.
Brian
Brian
