Mariner 25 hp problem
pescao
"Howdy guys,
I have a 2 str
"Howdy guys,
I have a 2 stroke, 1994 25 hp Mariner with wiring problems. I just need the color code or color matching or even a photo of the power pack to see if my engine is right.
Thanks in advance"
MERCURY/MARINER COMMON WIRING
MERCURY/MARINER COMMON WIRING COLOR CODES
WIRE COLOR(S) FUNCTION COLOR
SAMPLE
BLACK GROUND
BROWN Reference Electrode MerCathode System
ORANGE Anode Electrode MerCathode System
LIGHT BLUE/WHITE STRIPE Trim UP Switch
LIGHT GREEN/WHITE STRIPE Trim DOWN Switch
BROWN/WHITE STRIPE Trim Sender to Trim Gauge
PURPLE/WHITE STRIPE Trim "Trailer" Switch
GRAY Tachometer Signal
BLACK/YELLOW STRIPE Shorting or Stop Circuit
PINK Fuel Sender to Gauge
RED Un-fused Wire from Battery
RED/PURPLE STRIPE Protected (Fused) Wire from Battery and/or
Protected (12 Volt +) to Trim Panel Control
PURPLE Ignition (Switch) to 12 Volt Positive
TAN Temperature Switch to Warning Horn and/or
Temperature Sender to Temperature Gauge
TAN/BLUE STRIPE Alternate Color Temperature Switch to Warning Horn
YELLOW Starter Solenoid to Starter Motor and/or
Starter to Regulator (Charging Circuit)
YELLOW/RED STRIPE Start Switch to Start Solenoid to Neutral Start Switch
YELLOW/BLACK STRIPE Choke (Enrichener System)
GREEN/VARIOUS STRIPE Switch Box to Coil - Striped and Numbered
WHITE/BLACK STRIPE Bias Circuit (Switch Boxes)
