Sorry I took so long. I was working 7 days x 13 hrs. I slowed down again & my son wants his motor.
Just to make sure we are on the same page: One set of points has 2 orange & 1 green wire. The other set has 2 grey & 1 green. On either set 1 goes to the front magneto(coil), 1 goes to the coil pack(plug), And the green goes to the condenser. The rear magneto wires connect to nothing. I assume that is for an optional charging system.
My ohmmeter is different. It has 200, 2000, 20k, 200k, & 2000k. No x1 but 200 seems to be the most accurate. It jumps between 1.6 & 1.7 off grey or orange. The coilpacks(plug coil) only have one wire(orange or grey) from the points and a plug wire on the other side. There is a ground wire from the #1 coilpack bolt to a ground under the flywheel. I assume that replaces the wires & the negative is just ground. I checked from the lead to
the bolt hole. It was 2.1 on both. That's not right but they can't both be bad but still read the same, can they?
Even more interesting: I took #1 coilpack off. Both bolt holes are copper. Probably for grounding. If I check the hole where the ground wire was it is at 2.1, but the other hole reads 4.2 even if I sand it. Bad ground? That should not matter though because I have one good ground? On the final check I put the ohmmeter on 20k to get a reading. I got 6.77 on #1 and 6.66 on #2. Again, I apologize for the delay, but I really want to figure this out. Thanks.
