Mariner 2 HP impeller replacement
ggilles
"I have a Mariner 2, about 199
"I have a Mariner 2, about 1990, and have been unable to remove the drive shaft from the lower unit and water pump. It appears that the shaft should pull out, but I haven't been able to get it loose.
Can someone confirm that the shaft should be pulled from the lower unit.
Thanks,
Gary"
Not ususally! (It's a
Not ususally! (It's attached to the pinion gear.) Suggest you spring for a manual and see how it should be done. This site sells them.
Jeff
